After replacing the water pump the car does not start?
265,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
WLDKRZYKD
So, I just replaced my water pump myself (I got to mention that first because I'm not a mechanic... Just really like cars and didn't have the money to take it to a shop) and put it all back together only to find out it wouldn't start. At first i thought it had to be a timing issue, seeing how i just had the timing belt off... But i don't know for sure. Especially since i don't even hear the fuel pump prime when i turn the ignition to on. The water pump is holding water, which is good. But it would be even better if the dang car started. Any ideas? I have already checked the fuel pump relay fuse, and it was good. But the fuel pump doesn't seem to be getting power. I really hope I don't have to go fishing out the fuel pump from the tank. It worked just fine before I started the water pump replacement. There is just under 1/4 tank of gas in the car. Do I need more than that?
Nov 28, 2024 at 11:27 AM
  • 55,721 POSTS
Can you upload a short video of the engine cranking over from under the hood? That way I can tell if the timing belt was installed correctly. If the timing belt is not right, there will be no airflow through the MAF sensor which will keep the fuel pump from turning on. Please go over this video to see what ai am talking about:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Let us know what you find.
Nov 29, 2024 at 4:13 AM
WLDKRZYKD
Thank you for your response. Here is a short video of it trying to start.
Dec 2, 2024 at 10:52 AM
  • 55,721 POSTS
Thanks for the video. The engine seems okay, I would recheck the engine wiring harness grounds because it sounds like one of them was left off. If the grounds are all good let's see if the engine will run a starting fluid. Also, did you check for spark as in the video?
Dec 3, 2024 at 1:52 AM
WLDKRZYKD
I checked grounds and they looked good, but i will double check. Maybe i missed something. I am getting spark... I tested that. I thought the problem was with the fuel pump, but it seems to me that it would be unlikely something else, unrelated to the maintenance done, would fail. It has got to be in the timing or a missed wire or something. I think I have been looking at this car for too long.
Dec 6, 2024 at 6:22 AM
WLDKRZYKD
Oh, and I tried starter fluid, and it wouldn't start with it either. :(
Dec 6, 2024 at 6:29 AM
  • 55,721 POSTS
So it has spark and starting fluid would not help? Let's do a compression test to make sure the engine is okay, it sounds okay, but you never know.
Please let me know what the reading is.
Dec 7, 2024 at 4:20 AM
