Will not stay running after fuel pump replacement
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
DJSPEEDY12
I changed the fuel pump on my vehicle and broke the return line plastic where the hose connects to the pump. So I ran the return back into the tank through the fill tube. Started up test drove it and was fine. But now starts up and when driving does not want to stay running. Can you please help me with why it would be doing this.?
Oct 23, 2018 at 3:55 AM
  • 55,721 POSTS
When the engine stalls can you still hear the fuel pump running in the tank? Did you use an AC Delco part for the fuel pump?
This guide can help us get started to see whats going on.
Please run down these guides and report back
Cheers, Ken
Oct 24, 2018 at 6:05 AM
