Engine does not crank?
16,000 MILES
KEVIN PAYNE
My car won't turn over. I replaced the fuel pump, but it doesn't sound like it's running. The fuse and relay seem fine.
Jan 11, 2023 at 8:10 AM
  • 55,721 POSTS
So, the engine does not crank over (starter), or the engine will not run? If it will not run, try starting fluid to see if the engine runs then we can say it is the fuel system. Also, check all of the fuses and run the codes these guides can help. Can you upload a short video of the engine cranking over? That way I can see if the engine is hurt or not.
Check the fuses.
Run the codes.
Please go over these guides and report back.
Jan 12, 2023 at 2:12 AM
