Fuel pump
10,125 MILES • 3.8L • AUTOMATIC
TOADBOY1
  • 5 POSTS
When I drive my car for a long period of time. Then instantly when I come to a stop light the car dies. Then I started back up it startles and putt, putt and I smell gas. So I let it sit for a bout 1 minute and then it runs smooth again....
Jan 1, 2016 at 8:52 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner if it continues check fuel pressure 41-47 psi
Jan 1, 2016 at 10:27 PM
TOADBOY1
  • 5 POSTS
Okay
Jan 2, 2016 at 12:17 AM
TOADBOY1
  • 5 POSTS
I got a diagnostic and they said it's the mass flow sensor... They said 282.00 dollars to fix it is it possible to do it myself...
Jan 2, 2016 at 10:09 AM
HMAC300
  • 48,601 POSTS
yes that is the part between the air filter and engine, two clamps to remove it and unplug it. pic is what it looks like It may be in air cleaner this is for a 3.1L engine
Jan 2, 2016 at 11:50 PM
TOADBOY1
  • 5 POSTS
I change it.... My car is still doing the same thing when I turn the car on and unplug the mass airflow sensor connector the car immediately shuts off and won't start.... I read in another post that if it does that than its not the mass airflow sensor it's something else...... Any help please
Jan 4, 2016 at 12:49 PM
HMAC300
  • 48,601 POSTS
your check engine light will stay on until you pull the ecm fuse for 30 seconds to reset it make sure key is on. then try it and do what I said in first reply.
Jan 4, 2016 at 10:25 PM
TOADBOY1
  • 5 POSTS
I pulled off the TPS sensor and the car stays started and stays idle the same...... I ran a code the old school way and it gave me code 66.........
Jan 5, 2016 at 1:42 AM
HMAC300
  • 48,601 POSTS
code 66 a/c pressure sensor nothing to do with engine. what is fuel pressure?
Jan 5, 2016 at 2:30 AM
