Fuel pump is not getting power?
67,283 MILES • 5.7L • V8 • 2WD • AUTOMATIC
TYMONEY
  • 22 POSTS
Hi, I turn the key and I don't hear anything.
Feb 26, 2024 at 10:56 AM
  • 110,251 POSTS
I traced out the wiring for you below.
Here is what I need you to do first. Check the ECM B fuse in the under-hood fuse box. In addition to checking the fuse, make sure there is power to and from it.
If that is good, remove the fuel pump relay. On the relay itself, you will see a number identifying each pin. Locate pin 30 and pin 87. Then, take a jumper wire and jump the two pins I mentioned. By doing this, you will be sending power directly to the fuel pump. This is a test to see if the pump itself may be an issue.
Do these two tests and let me know what you find.
Feb 26, 2024 at 12:18 PM
TYMONEY
  • 22 POSTS
Hi Joe,
Man, it's appreciated but give me a minute to work on the van it's going to be a couple days I will be in touch.
I wanted to add the fuel pump has been changed since this last Friday. But not the wiring connector wasn't changed. It cranks but there is no sign of the fuel pump turning on.
Feb 27, 2024 at 7:33 AM
  • 110,251 POSTS
Hi:
You are very welcome and take your time. Let me know what you find when you have a chance. Also, let me know if you have other questions.
Feb 27, 2024 at 10:15 AM
TYMONEY
  • 22 POSTS
Hi man,
It has been a minute but it's running the van it's sputtering from 10 MPH to 25 MPH then smooth at times in reverse it runs fine.
Long story short it was a wire under the driver's seat, and it started right up.
But is it possible for you to get me a diagram to the fuel pump gas lines to be sure they are all going in the right direction?
Mar 11, 2024 at 9:11 AM
TYMONEY
  • 22 POSTS
Joe, man, hope everything is wonderful on your side.
  • 110,251 POSTS
The only pic I have is attached below (very generic). Let me know if it helps, and by the way, I'm glad to hear you got it fixed. Good job.
See pic below.
Mar 11, 2024 at 12:20 PM
TYMONEY
  • 22 POSTS
30 has power 87 has power 86 has power for 2 seconds then stops with key on . Any ideas?
Mar 25, 2024 at 10:47 AM
TYMONEY
  • 22 POSTS
Hi Joe, man, it's the van again not starting when I test with 85 fuse the EGR valve clicks but van not starting fuel pump is just clicks.
Mar 25, 2024 at 10:48 AM
  • 110,251 POSTS
Welcome back. This isn't good news. LOL As far as the clicking when trying to start it, do you mean the starter just clicks? If so, take a look through this link and let me know if it helps:
If it isn't the starter, let me know. Additionally, let me know if you checked for diagnostic trouble codes.
Mar 25, 2024 at 1:08 PM
TYMONEY
  • 22 POSTS
It's late but man it's turning over but not starting . The fuel pump makes no sound just a click and engine turning over.
Mar 25, 2024 at 1:52 PM
TYMONEY
  • 22 POSTS
Afternoon Joe, man, I'm here with the van turning over not starting don't hear fuel pump. It's not starting no codes on obd2scanner. Any ideas?
Mar 26, 2024 at 2:05 AM
  • 110,251 POSTS
Have you checked or switched out the relay? Just as a confirmation, does it start if you use starting fluid and then stall?
Mar 26, 2024 at 11:44 AM
TYMONEY
  • 22 POSTS
Yes, switched relays it's just turning over fuse blew when jumping it ECM b fuse and ECM 1 fuse when starting it I think I'm going to look under the PCM and ECM is there a diagram for wiring.
Mar 26, 2024 at 11:52 AM
  • 110,251 POSTS
The wiring schematic that includes the PCM is tied into the powertrain management circuit and is four pages long.
I attached the entire schematic below. However, to make it readable, I had to cut each page in half. I did overlap them so you can follow from one to the next. Additionally, I highlighted the wiring related to the two fuses that failed and indicated the location of the fuel pump relay.
The PCM is located on pages one and four in the manual. Therefore, they are pics 1 and 2 below and pics 7 and 8 because I cut the pages in half.
Let me know if this helps.
Mar 26, 2024 at 12:57 PM
TYMONEY
  • 22 POSTS
Sweet thanks a bunch.
One more diagram the fuel pump wiring harness I think the wiring may be connected improperly. I see an orange wire on it. I'm not sure that it goes to the fuel pump. I'd need a diagram to be sure.
Mar 26, 2024 at 2:04 PM
  • 110,251 POSTS
At the pump, there should be three wires, black, gray, and purple. Where are you seeing an orange wire? Can you tell where it is coming from?
See pic below.
Mar 26, 2024 at 2:24 PM
TYMONEY
  • 22 POSTS
The fuel pump connector piece goes to 4 wires the orange wire from the connector went to the grey wire, I think. I'll get a picture or the connector tomorrow.
Mar 26, 2024 at 4:51 PM
TYMONEY
  • 22 POSTS
Hey Joe good afternoon. This was the fuel pump connector piece that was on there I replaced it the same way and I think that's the issue.
Mar 27, 2024 at 3:09 AM
  • 110,251 POSTS
That isn't even the right connector. It should be square, so someone was certainly into it. Is the connector in the fuel pump itself work with this connector?
You indicated the orange wire was tied into the gray. Here is my dilemma. I'm not sure what the person did or set things up. I have factory information, but this isn't a factory connector. I attached a pic below of the connector.
See pic below.
Mar 27, 2024 at 11:20 AM
TYMONEY
  • 22 POSTS
It's the same one that came with the fuel pump maybe a color or 2 different it has connectors. here's a picture.
Mar 27, 2024 at 11:26 AM
TYMONEY
  • 22 POSTS
The new connector works and fits it.
I believe it's wire wrong like you said.
Mar 27, 2024 at 11:31 AM
  • 110,251 POSTS
Do you get battery voltage at the orange wire? (I believe you said it is connected to the gray wire.)
Also, is there continuity to ground via the black wire?
Mar 27, 2024 at 11:45 AM
TYMONEY
  • 22 POSTS
Yes, the orange wire set to be grey wire would be the 87 on the relay. All power is there even the 85 cones on for 2 seconds and stops.
Mar 27, 2024 at 11:49 AM
TYMONEY
  • 22 POSTS
Joe, what do you think I should do disconnect the fuel pump wires and only plug in the 3 wires instead of 4.
Mar 28, 2024 at 3:47 AM
TYMONEY
  • 22 POSTS
Then man does it show and ground connections to the frame for the fuel pump?
Mar 28, 2024 at 6:07 AM
  • 110,251 POSTS
The ground for the fuel pump is G103. It is located at the rear of the right cylinder head. That would (should) be the passenger side. I attached the schematic below.
See pic below.
Mar 28, 2024 at 1:02 PM
TYMONEY
  • 22 POSTS
Key off on negative 30 is on ground nothing on the others off.. key off.... on positive 30 is off 87 on 86 is on 85 off. Turn key 30 is off 87 on 86 on 85 2 seconds then off.
Mar 29, 2024 at 6:16 AM
TYMONEY
  • 22 POSTS
Hi Joe, happy Friday, that's where I'm at the connector is right with grey to grey, purple to purple black to black with stripe to the same every is connected right. I'm going to open the PCM to see if it's going to be what it's supposed to be.
Mar 29, 2024 at 6:18 AM
TYMONEY
  • 22 POSTS
The first paragraph is the power from the fuel pump relay. As of right now, is the right let me know please.
Mar 29, 2024 at 6:19 AM
  • 110,251 POSTS
The power from the relay should be the gray wire. As far as what you are finding, it does sound correct.
I'm sorry for the delay in getting back to you. It has been a rough couple of days.
Take care and I hope you have a Happy Easter.
Mar 30, 2024 at 1:59 PM
TYMONEY
  • 22 POSTS
Hey Joe happy Easter. I was wondering does the van have an inertia switch?
Hope all is well with you.
Mar 31, 2024 at 7:00 AM
  • 110,251 POSTS
The van doesn't have an inertia switch. Ford uses them and not GM. On a GM, the ECM is what controls power shut down to the pump.
Joe.
Apr 1, 2024 at 8:45 AM
TYMONEY
  • 22 POSTS
Joe man happy Monday well I'm going to replace the ignition coil and I've cleaned the PCM it had brake fluid in it heavy and did some soldering too repair. We need it this weekend for big family events this Sunday.
Is there anything you can think of that may help get it started?
Apr 1, 2024 at 10:12 AM
  • 110,251 POSTS
I'm not sure what to add. It sounds like you have done a lot of work. Let me know how things turn out for you.
Apr 2, 2024 at 3:29 AM
