Fuel pump
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAIN IN THE A** CAR
I was driving my car and it stopped accelerating. I can drive short distances but after driving for awhile it just starts going down in speed and eventually stalls out. I changed the fuel filter but do I need to change the fuel pump? After it sits for awhile it will start back up. I can hear the fuel pump kick on.
Oct 6, 2018 at 3:10 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It's possible your fuel pump is weak/failing. I would suggest performing a fuel pressure test. If you do not have access to a tester your local auto parts stores have a tool loaner program and can rent you one. I have attached a tutorial showing you what is involved. Your fuel pressure should be listed on the chart I attached. You did not specify your car's engine displacement so I attached all. The abbreviations mean KOER-(Key On Engine Running) and KOEO- (Key On Engine Off). Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Oct 6, 2018 at 1:19 PM
PAIN IN THE A** CAR
Thank you. I will check into this with my local auto parts store. I will let you know how it goes.
Oct 6, 2018 at 2:53 PM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks again for using 2CarPros.
Danny-
Oct 6, 2018 at 3:27 PM
