fuel pump
190,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
KINGRI
truck quit while I was driving down the road.
I turn the ignition key on the fuel pump has 12 volts and runs for one or two seconds, then quits running. At this point there is 6.32 volts at pump. I assumed fuel pump since there was no pressure at port on fuel rail. I have bed off so pump is accessible. I pulled pump off to go get another and decided to test straight of battery and it ran in my hand. Then started checking voltages. I plugged pump back up and left sitting on frame. Pulled relay and inserted a jumper and pump runs continuously. Is there a fuel pressure sensor that would tell PCM to shut down the pump after a couple of seconds?
Jul 12, 2016 at 3:44 AM
WRENCHTECH
  • 20,760 POSTS
That is exactly how it is supposed to work. You get a two second prime and then it shuts off until the computer sees a crank RPM signal.
Jul 12, 2016 at 3:56 AM
