Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-250
Engine
Symptoms
Not Running
Fuel problems
1989 FORD F-250
160,000 MILES • 5.8L • V8 • 4WD • MANUAL
BILL POWELL2
MEMBER
I have fuel to fuel rail but none after. Will not start.
Mar 20, 2018 at 7:13 AM
Experienced Mechanic
Will the engine run if you spray starter fluid in it the intake?
This guide can help as well.
Cheers, Ken
Mar 22, 2018 at 3:39 AM
BILL POWELL2
MEMBER
I put gas in a spray bottle, sprayed it in throttle body and it runs until out of gas. I got fuel to the rail but no farther.
Mar 22, 2018 at 6:09 AM
Using a test light check to see if the injectors are getting a pulse. Here is a guide to help you see how.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Mar 23, 2018 at 2:49 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
