My engine will not start up what's wrong?
189,000 MILES • 4.9L • 6 CYL • 4WD • MANUAL
MYLES DAVID KIRSTEATTER
My truck ran fine up until I got to work, now it wont start it seems like it's not getting any fuel. Any suggestions on where to start or what could be the problem?
Dec 12, 2019 at 6:17 AM
Good afternoon,
Can you hear the fuel pump run when you turn the key on?
When you crank it, does the tachometer move up a little?
Did you check for spark?
https://www.2carpros.com/articles/how-to-change-spark-plugs
May 31, 2021 at 5:47 AM
As far as I can tell I cant hear the fuel pump so I got new one fired right up thanks!
