Fuel problem
200,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
FELIPE501
  • 17 POSTS
when the engine idle I can press the pedal and runs great, but when i test drive it it seems like it is not getting gas. would like to know how the fuel pump works when i test drive it, thank you .
Mar 14, 2019 at 11:26 AM
Good evening,
The fuel pump works the same at idle as it does under load.
It may not be the pump. It could be something else such as a clogged catalytic converter not allowing the engine to breathe.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Mar 14, 2019 at 11:38 AM
