Codes p0172 and p0175, fuel problem?
157,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
KINGJD123
  • 104 POSTS
When i turn it on it struggles a little and then idles rough but will stay on but then if i press accelerator down let it go it wants to shut off. my fuel trim is showing -34 all my injector pulse are active and normal the
DTC code i got was p0172 and p0175 i was think vacuum so i changed all intake gaskets and check vacuum i have pics of what those show i reset codes and they haven't come back but it is still dying after i hit accelerator also i am not having any misfires.
Apr 5, 2024 at 12:41 PM
  • 110,248 POSTS
Are the fuel trims still the same? As far as a neg 34 STFT, that indicates the PCM is trying to cut the amount of fuel to the cylinders. Often, that is a result of a faulty fuel pressure regulator. Have you checked if the pressure is within the manufacturer's specifications? If not, that is where I would start.
Here is a link that explains in general how to check it:
I attached the manufacturer's fuel pressure specifications below.
See pic below.
Apr 5, 2024 at 1:46 PM
KINGJD123
  • 104 POSTS
Just checked it and it is in spec. what is the next you would try and yes they are still negative?
Apr 5, 2024 at 1:59 PM
  • 110,248 POSTS
The next thing to check is how quickly the fuel pressure drops off when you turn the key off. There could be an injector issue (leaking). Also, make sure there are no air restrictions between the air filter and throttle body.
Apr 7, 2024 at 11:21 AM
KINGJD123
  • 104 POSTS
Fuel is good and no leaking.
Apr 19, 2024 at 12:36 PM
  • 110,248 POSTS
I went back through the pics you attached above. I didn't notice any for the engine coolant temperature sensor. Before starting the vehicle, what signal is the ECT sending to the PCM?
Apr 19, 2024 at 1:38 PM
KINGJD123
  • 104 POSTS
ECT is reading valid outside temperature I thought it could be IAC Valve so change throttle body same problem could the intake runner make it run rich on both banks. When I was cleaning intake, I took the runner off.
Apr 19, 2024 at 1:42 PM
  • 110,248 POSTS
Anything is possible. A failed runner can cause air/fuel mixture issues. The runners are actuated under full throttle, so it could be related.
Have you had a chance to inspect them?
Apr 20, 2024 at 2:58 PM
KINGJD123
  • 104 POSTS
It was mds system.
May 7, 2024 at 7:14 AM
  • 110,248 POSTS
I'm not a fan of the MDS system. Were you able to resolve the issue?
May 7, 2024 at 12:00 PM
KINGJD123
  • 104 POSTS
May 7, 2024 at 12:12 PM
  • 110,248 POSTS
That's good news. I'm glad to know you found the issue and were able to resolve it.
Take care of yourself and feel free to come back anytime in the future.
May 7, 2024 at 12:36 PM
