Fuel pump is good. Weak power to pump. Does the ECM control fuel pump power or is there a relay somewhere other than the distributor. Swapped out ECM and same problem. Distributor and fuel pump are new. Does the resistor on the fuel delivery system inside the tank serve a purpose that would effect the delivery of fuel? It was running fine until I let it set for a couple of months over the winter. Thanks for any input you have. I am stumped.
Mar 14, 2018 at 1:32 AM
