Fuel pressure test
182,000 MILES • 2.0L • 4 CYL • AUTOMATIC
MARY CATTERLIN
Hi, I would like to check the fuel pressure in my car. I can’t find a fuel pressure test port though. Does anyone know the location? Thank you for your help!
-Mary
Sep 14, 2019 at 10:18 AM
  • 55,682 POSTS
There is no valve so you must interrupt the fuel line and install a gauge here is the location of the fuel pressure sensor which you can change but if you use a scanner it can tell you the fuel pressure here is a guide you will need to use a better scanner than in the guide. To check the pressure the Rotunda Fuel Pressure Test Kit #134-R0087 or equivalent.
Let me know what you find, check the diagrams below.
Sep 15, 2019 at 12:13 PM
