Fuel pressure test
2008 SATURN AURA
150,000 MILES • 3.6L • V6 • FWD
CAMP.
  • 21 POSTS
Well, I did a fuel pressure test on my car, the test showed with the car not running , but with cycling the key on and off, the pressure some where around 50 - 53 pounds of pressure. Okay, with the car running the pressure still reading at the same reading, but my needle on the gauge begins fluctuating rapidly between 49 - 53 pounds a pressure, and with the car off the pressure drops from 53 pounds a pressure to 29 pounds ps. with in three minutes. can you please help me out and steer me in the right direction? thank you
Jan 16, 2017 at 10:55 PM
STEVE W.
  • 15,351 POSTS
What was the reason you did the pressure test? No start, hard starting?
Jan 17, 2017 at 1:29 AM
CAMP.
  • 21 POSTS
Car had a really bad mis and shake.
Jan 17, 2017 at 1:32 AM
CAMP.
  • 21 POSTS
Found a bad coil of plug was causing the the problem , but what got me is the fuel pressure test .The car running good after I swapped out coil wire, but the fuel pressure test that is another story.
Jan 17, 2017 at 1:38 AM
CAMP.
  • 21 POSTS
One more thing , the car runs good like I was saying , but after it gets nice an hot say I drove and got gas , if I cut the car off and filled up with gas it take hard time to start. Now,If I get gas and leave the car running when I remove the gas top the car begins missing badly and check engine light comes on.
Jan 17, 2017 at 1:44 AM
STEVE W.
  • 15,351 POSTS
Check the EVAP purge solenoid, you'll probable find it's sticking open.
Will cause both issues as the engine is seeing a vacuum leak with it open. And the hard starting is because you filled it and the purge system starts drawing in a lot of extra fuel vapor through the port.
Jan 17, 2017 at 7:15 AM
CAMP.
  • 21 POSTS
Hey Steve , thank you i'm going to try that I will send back a report and let you guys know how it worked out for me.
Jan 17, 2017 at 7:30 AM
