Fuel pressure regulator keeps going bad
190,000 MILES • 4.2L • 4 CYL • 2WD • AUTOMATIC
RUTHLESSS89
  • 6 POSTS
Fuel pressure regulator was leaking fuel out of the vacuum line, so I bought a new one after a few hours. The new one did the same thing. I thought it was defective, so I went and bought a second one. After a few hours the same thing happened again; fuel coming out of the vacuum line. Why does the fuel pressure regulator keep going bad so quickly? what is making the diaphragm let's fuel by like that
Jan 26, 2022 at 6:41 AM
  • 110,248 POSTS
That is a very good question. By chance, are you purchasing original GM parts or is it something aftermarket? Were both of the new regulators the same brand?
Also, with the engine running, is there a vacuum to the vacuum hose at the regulator?
Jan 26, 2022 at 10:00 AM
RUTHLESSS89
  • 6 POSTS
They were after market regulators and I'm sure they were the same brand I got them on Amazon from the same seller I just ordered another one, but from a different seller and the vacuum line is just pouring fuel into the air box. I'm not sure if there is vacuum at the regulator, I never checked that all I did was change it both times and it started and ran beautifully so I figured it was fixed. they both lasted long enough for me to run a few errands then truck wouldn't start into the vacuum line off and it was pouring out fuel.
Jan 26, 2022 at 3:08 PM
  • 110,248 POSTS
Where is the fuel coming from into the airbox? The vacuum hose should run to the engine intake.
Next, the fuel system has a return line to the fuel tank. If the problem continues, I'm questioning if something has plugged the return. However, since it ran well for a few trips, I'm even questioning that. If you look at pic 1, it shows the fuel lines. The highlighted one is the return.
As far as the regulator is concerned, it's a very simple design. The fuel pressure regulator is a diaphragm relief valve. The diaphragm has fuel pressure on one side and regulator spring pressure on the other side. The fuel pressure regulator maintains a constant pressure across the fuel injectors under all operating conditions. If it keeps failing, either we have poorly made regulators (which may be the case), or there is extreme pressure being built that it can't handle. That doesn't make sense to me yet, but anything is possible.
Let me know if the new one takes care of the issue. If it doesn't, return it and get your money back. Get one at a parts store manufactured by a well-known company. For example, Delco, Standard, and there are many others are well known for what they do. Often times when you get parts from online, it's difficult to tell where they came from.
Keep in mind, this is a theory at this point.
You know, I didn't realize how expensive they are for this vehicle. I did a little research for you and found a few on rockauto.com that I recognize. I attached it in pic 3.
Let me know what I can do to help.
Jan 27, 2022 at 10:04 AM
RUTHLESSS89
  • 6 POSTS
Thank you. The new regulator is supposed to be here Tuesday. I'll reach out to you after I see what happens.
If it's getting too much pressure, how do I fix that? And yes, it's the Intake that the vacuum line hooks to when I disconnect it and pull that intake box off that it hooks up to, I can pour the gas right out of it. thank you again.
Jan 28, 2022 at 1:32 AM
  • 110,248 POSTS
As far as the pressure, if it has no escape, it will build. The system has a return built into it.
The fuel pump sends pressure to the injector rail. The regulator is supposed to release the pressure when it reaches a specific point, allowing the unused fuel to return to the fuel tank. If there is no place for it to go because the return is plugged, the regulator can't do its job simply because there is no place to release the fuel. So, it will continue building until it "potentially" break the regulator.
If the new regulator doesn't help, we need to disconnect the regulator, open the fuel tank cap, and see if you can blow compressed air (low psi) through it confirming it isn't plugged. If it is, it will require the removal of the return line for inspection and to locate where the problem exists.
Please understand, at this point, this is a theory. All part of troubleshooting. Sometimes I drive myself nuts thinking ahead. LOL
One thing, is it possible for you to take a pic of the hose filling the airbox with fuel and upload it for me to see? Where does the opposite end of that hose go to? For some reason, I can't picture how fuel is getting to that point.
Take care of yourself. And, hang in there. We'll get it figured out one way or another.
Jan 28, 2022 at 10:34 AM
RUTHLESSS89
  • 6 POSTS
The little vacuum line that comes off the regulator and connects to the air intake box that sits on the top of the engine and connects to the, but I'll send a picture as soon as I get a chance thank you for helping me out. I've been driving myself crazy trying to find the problem.
Jan 28, 2022 at 8:06 PM
  • 110,248 POSTS
You are very welcome. Today's vehicles can drive anyone crazy. LOL No pun intended. LOL My confusion is there should be one vacuum to the regulator that then goes to the intake manifold and not the airbox. That is where I'm getting confused. I even went through different manuals, and they are showing me the same. Sorry, not being there makes it a bit more difficult. I was thinking maybe I was missing something.
Take care of yourself and I'll watch for your reply.
Jan 29, 2022 at 5:10 AM
RUTHLESSS89
  • 6 POSTS
It is the intake that it goes into?
Jan 29, 2022 at 8:39 AM
  • 110,248 POSTS
Let me see the pic when you upload it. That way I'll know for sure. However, I suspect it is the black plastic intake manifold you are referring to.
Jan 29, 2022 at 1:50 PM
RUTHLESSS89
  • 6 POSTS
Yes it is.
Jan 29, 2022 at 4:43 PM
  • 110,248 POSTS
Yep, that's part of the intake manifold. That makes sense to me.
Jan 30, 2022 at 8:54 AM
RUTHLESSS89
  • 6 POSTS
But what would make the gas keep coming out of the vacuum line? so far so good, I'm hoping that the other 2 were just junk. I'll let you know how it goes over the next couple of days.
Feb 7, 2022 at 6:54 PM
  • 110,248 POSTS
The only thing I can think of is somehow the vacuum in the airbox was drawing it in somehow.
Let me know if it continues to work properly. I'm interested in knowing. However, I have a feeling the parts were faulty.
Take care of yourself and I look forward to hearing from you again.
Feb 8, 2022 at 10:55 AM
RUTHLESSS89
  • 6 POSTS
Hello, just wanted to let you know that I think it's fixed. my wife finally took the car on a good long drive and the fuel pressure regulator seems to be fine now.
But now I have a check engine light on. I had to also replace the crankshaft position sensor due to me accidentally breaking it off. so, I bought a new one, but it on reset my engine light and it went out for a couple minutes and came back on, so when I checked it with the tester this time it says the same thing crankshaft position sensor circuit. so, I went and bought a new pigtail just in case I damaged the old plug and a new sensor, and the same thing happens service engine light comes on after a few minutes. the light never was on before I broke the old one. any idea about this problem? lol, thank you
Mar 10, 2022 at 2:22 AM
