Where is the Fuel Pressure regulator located?
883,741 MILES • 5.8L • V8 • 2WD • AUTOMATIC
HIPPLESS1
  • 9 POSTS
Where is the Fuel pressure regulator. Smelling gas all the time now eating a lot of gas just started I need to know where is the fuel pressure regulator located at. And do you have the part number along with a manual. I would like to down load a manual for this van.
Mar 15, 2023 at 4:11 AM
  • 110,248 POSTS
On a carbureted engine, a traditional regulator isn't used. There is a needle and seat in the carb that stops the fuel from entering. Also, the fuel pump also controls the pressure.
If you look below, I attached the steps for testing pressure specific to this vehicle. This is for a 2bbl carb. If the van has a 4bbl, let me know.
Next, if you are smelling fuel, check the fuel lines between the tank and the pump. Also, check around the carb for evidence of a leak. When checking the steel lines, there could be rusted pin holes that you don't see. However, the line is usually stained. Also, check to make sure the rubber hoses are not dry-rotted. Check the fuel tank as well for evidence.
Let me know what you find. Also, I am basing this vehicle still having a mechanical fuel pump. This is right around the time Ford changed to fuel injection.
See pics below. They used two different fuel filters. Both are at the carb area.
Mar 15, 2023 at 1:16 PM
HIPPLESS1
  • 9 POSTS
The lid on top of the air filter says 4valve oh something and I have 2 gas tanks my motor is the 5.8 Windsor where would the gas pressure regulator if it has one be located at. I'm going to see if there any lines disconnected on the carb.
Mar 15, 2023 at 3:22 PM
  • 110,248 POSTS
If it is fuel injected, it will be positioned downstream from the fuel injectors or on the fuel rail. If it has a carb, it is built into the fuel pump.
I need to determine if this is fuel injected or not. As far as the 4 oh, could the last letter be a V?
Is it possible for you to take a couple of pictures from the top of the engine so I can determine if it is fuel injected? I'm finding conflicting info.
One last request. Let me know the 8th digit in the VIN.
Mar 16, 2023 at 11:53 AM
HIPPLESS1
  • 9 POSTS
This is what I'm talking about and the motor is a 351windsor carburetor 1985 Econoline e150 van it's called a thermactor idle vacuum valve part number 9g328.
Mar 30, 2023 at 2:09 PM
  • 110,248 POSTS
Hi.
I attached the part description and operation below for you. Also, this has to be a carburated vehicle because nothing it indicated in any of my manuals related to fuel injection. Therefore, the fuel pressure is regulated by the fuel pump.
Let me know if this helps.
Mar 31, 2023 at 3:19 PM
HIPPLESS1
  • 9 POSTS
Hello, okay, where is the air bypass system located that your showing me in the diagram?
Apr 4, 2023 at 10:42 AM
  • 110,248 POSTS
It should be at the rear of the passenger side top of the engine. I attached a pic below. See if it helps you locate it.
See pic below.
Apr 4, 2023 at 12:58 PM
HIPPLESS1
  • 9 POSTS
Where my tiv is it's in the front passenger's side just a little to the left and behind the distributor Wrong last I don't have that type I have the 9g328 thermactor idle vacuum valve.
Apr 4, 2023 at 1:41 PM
  • 110,248 POSTS
I need to know if it has a 4bbl or a 2bbl. That is the only thing I can think of that would make it different.
Let me know. Also, the part number you supplied, is that an OEM part number? I'm struggling because of the model year. I don't have a ton of information.
Apr 5, 2023 at 10:54 AM
HIPPLESS1
  • 9 POSTS
Joe it's a 2 barrel 1985 Econoline e150 van 5.8l Windsor part 9g328 number I'm trying find out where I have to connect the hoses to and where are the place are located at to connect the one hose that's towards the top of the thermactor idle vacuum valve.
Apr 6, 2023 at 9:07 AM
HIPPLESS1
  • 9 POSTS
This is the part I need to connect from wherever.
Apr 6, 2023 at 9:09 AM
  • 110,248 POSTS
See pics below. That is where the vacuum hoses should run to. The different solenoid valves shown in pic 2 all get vacuum from the main source, the intake. See if either of these pics can help you locate what is needed.
Sorry to be vague. This is an older one that I haven't seen for a long time. All I have are the schematics to figure out where they go.
Apr 6, 2023 at 4:05 PM
HIPPLESS1
  • 9 POSTS
Hello Joe, those don't show the tiv vacuum valve part number from ford is 9G328 thermactor I need to know where the vacuum hose that's just under the top rim connects to and the hose route to that part it connects to remember 1985 Econoline e150 van with 5.8 Windsor motor 2barrell carburetor. And is there a replacement part for the part number I just gave upu. I'm having a hard time finding the thermactor idle vacuum valve.
Apr 7, 2023 at 3:33 AM
  • 110,248 POSTS
As far as the part number is concerned, it isn't listed in any of my manuals, so I'm not sure if it has changed.
As far as the valve is concerned, I attached two pics below. This is the only thing I have left. LOL Take a look and let me know if this helps.
Other than these, I would need to be with you to see exactly what you are dealing with. The lack of manual specifics for me is due to the model year. I wish I had a better response.
Let me know and I hope you have a good Easter,
Apr 7, 2023 at 2:19 PM
