Fuel pressure regulator what PSI should it be?
145,450 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
AZDANNO04
  • 378 POSTS
Replaced Fuel pump and don't know which fuse is or relay for fuel system and what PSI should be? I just got the fuel pressure kit to test it.
Oct 15, 2023 at 10:05 AM
  • 110,251 POSTS
No problem whatsoever. To get you started, here is a link that explains in general how to test both fuel pressure and the fuel pressure regulator:
If you look below, I attached the manufacturer's testing instructions which include diagnostics at the end. Take a look through them and let me know if they help.
Let me know what you find or if you have questions.
Oct 15, 2023 at 12:57 PM
