fuel pressure cut off switch
1994 JEEP GRAND CHEROKEE
215,610 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
HPPRS2
Vehicle acts like it is not getting the fuel. Put on a new fuel pump. Replace the fuse for fuel pump. Relay is good. The fuel pressure is 20. Not sure if I have a bad fuel pump. Can the fuel pressure cut off switch be bad and if so were can I find it?
Mar 4, 2018 at 10:46 PM
Good morning.
No, there is no cut off switch. That is a system Ford uses.
20 lbs? That is low. did you use a new pump? If you did, what brand did you use?
Mar 4, 2018 at 11:10 PM
The pressure should be 35 lbs running.
Make sure the connections to the pump are good, clean and no damage to the pins.
Did you change the filter as well?
Mar 4, 2018 at 11:12 PM
