Fuel pressure check?
2007 TOYOTA CAMRY
300,000 MILES • 2.4L • AUTOMATIC
JOE1953
  • 785 POSTS
what is the fuel pressure psi number is? i check the fuel pressure while cranking the numbber was 34psi. when engine running the number is 44psi is those in normal range?
Jun 19, 2026 at 11:11 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,423 POSTS
Normal fuel pressure is about 44 to 50 PSI with the engine running. Toyota’s 2AZ-FE fuel spec is listed at 304–343 kPa, which converts to about 44–50 PSI. Here is a video to go over to help with instructions in the diagrams below for your car.
https://www.youtube.com/watch?v=kgEixCsqcYM
Are you still fighting the #3 and 4 cylinder misfire? Please upload a short video in your response of the problem, so I can see what's going on. Check out the images (below). Let me know how it goes
Jun 20, 2026 at 4:46 PM
