Low fuel pressure, will not stay running and shuts off while driving?
152,000 MILES • 1.4L • 4 CYL • TURBO • AUTOMATIC
DIANN06
The car won’t stay running, it shuts off while driving. It’s not getting enough fuel pressure, and I just replaced the fuel pump.
Apr 3, 2025 at 7:42 AM
  • 55,549 POSTS
There is a fuel pressure sensor which sounds like it is weak or gone out, I would run the codes to see if any are stored, here is a guide to help and the location of the sensor so you can change it out if there is a code for it.
Apr 4, 2025 at 4:15 AM
