Fuel pressure specs
100,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
  • 239 POSTS
Need to know the fuel pressure with/without the fuel pressure regulator.
Jun 18, 2020 at 9:33 AM
I attached the spec as you requested. Let us know if you need more info. Thanks
Mar 2, 2021 at 1:37 AM
PACIFICISLANDER
  • 239 POSTS
Fuel pressure is 36 psi with the PRG however it will start every time you spray fuel in TB- is like it's not getting spark, but it does. what's with this? replace crank sensor/igniter and still happening all the time.
Just to clarify, it doesn't start unless you spray starter fluid? If that is the case you have a fuel issue not a spark issue.
I suspect you have an issue with the regulator. Basically you have pressure to the rail but it is not being delivered to the injectors because the regulator is sticking allowing too much fuel to return to the tank.
I attached the testing that you need to find this out. Let us know what you find. Thanks
PACIFICISLANDER
  • 239 POSTS
What about the distributor if there's a problem with the coil, pick-up coil, and condenser.
No. Not if the engine starts and runs on starter fluid. This proves out all the ignition system is working and points directly to a fuel issue. If you are adding fuel with the starter fluid, and it starts then what you are adding is the issue. It is not getting fuel. Let's run through the regulator test and I bet you will find your issue.
PACIFICISLANDER
  • 239 POSTS
Testing FPR without vacuum 44 psi w/vacuum 38 psi seems doing okay.
Okay. But again, you said the vehicle only starts if you use starter fluid, correct? That tells us that the injectors are not firing.
Does it start on starter fluid and keep running or does it shut off as soon as the starter fluid is used up?
You said in a previous post that "it will start every time you spray fuel in TB- is like it's not getting spark"
You have this backwards. If it starts on starter fluid then spark is fine. You are not getting fuel into the cylinders. Testing fuel pressure just proves out that your fuel pump is able to get fuel to the rail. We need to use a noid light on the injectors and see if the PCM is pulsing the injectors.
Let me know if you have questions.
PACIFICISLANDER
  • 239 POSTS
Does it start on starter fluid and keep running. Yes, then stay running until I shut it off, but when you give it time like 8 hours that's when it refuses to start. put starter fluid again it will fire up. Puzzle this is over and over again.
PACIFICISLANDER
  • 239 POSTS
I changed the FPR and still the same next in line is check the fuel pump for the correct fuel specs.
PACIFICISLANDER
  • 239 POSTS
So what do I check other than the fuel pump?
When you say FPR you mean you replaced the fuel pressure regulator, correct?
If you have replaced that then yes, we need to check the fuel pressure after it sits for 8 hours. Do not try to crank the engine after it sits. Just hook up the gauge and then turn the key to the on position. This is the one before the engine cranks.
Tell me what the pressure is when you turn it on the first time. Then try cycling the key a number of times and see if it builds more pressure.
The pressures you gave earlier are actually correct but I suspect you took these after the engine had started. We need to see what they are when it has sat overnight.
PACIFICISLANDER
  • 239 POSTS
What fuel pressure reading are we looking at, when I turn the ignition switch on?
PACIFICISLANDER
  • 239 POSTS
It's sparking but it's not as we expect blue snapping. it fires up when you just turn it off then restart about 3-5 minutes fires up again. no need for the starter fluid.
Okay. So you only need the starter fluid after it sits overnight? Then after it starts using the starter fluid and you shut it off then restart, it fires right up? If this is the case, we need the fuel pressure when you turn the key to the on position before you use the starter fluid to get it started.
If you have a weak spark, starter fluid would have no effect on it. If you have weak spark then why adding starter fluid gets it to start? Plus if you had a weak spark then why does it restart just fine after you get it going the first time?
I see no issue with the spark because you are not doing anything to change the spark to get it to start. You are only adding fuel so I see no need to suspect you have an ignition issue.
Again, when you are adding starting fluid, you are adding fuel. If it starts using this then the spark is fine and you have a fuel issue.
Let the car sit until it will not start without using starter fluid and just turn the key to the on position so the fuel pump primes the system and tell me what the pressure is.
PACIFICISLANDER
  • 239 POSTS
Thank you very much for help and patience. I nailed it to the fuel pump due leaky check valve pressure reading kept dropping fast every time I check it .so I concluded that's the fuel pump. thank you very much.
Awesome. Thanks for updating us as well. That info will surely help others when they are having a similar issue. Glad you got it resolved. Thanks for using 2CarPros.
PACIFICISLANDER
  • 239 POSTS
Kasekenny1
I change the fuel pump again to include the fuel pressure regulator, however when it starts it seems like it's not getting enough fuel and it idles real low. need help again.
I see you started a new post. Let's address this over there since you already have it started. I will jump over and we can figure this out. Thanks
PACIFICISLANDER
  • 239 POSTS
Tom, I think it's coming from a weak spark.
PACIFICISLANDER
  • 239 POSTS
Do you know the wiring colors for the fuel pump and fuel sending unit?
Mar 2, 2021 at 1:38 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just here to add my 2 cents.The sending unit is built into the in-tank fuel pump.Here is the wire colors for the fuel pump circuit. I've attached 2 pictures below.Hope this helps and thanks for using 2CarPros.
PACIFICISLANDER
  • 239 POSTS
The fuel pressure is high 80-100psi key on with 3-fuel pump use. What is causing it to be high? also changed the fuel pressure regulator.
DANNY L
  • 5,648 POSTS
Hello again.
It sounds like you have a defective fuel pressure regulator. That pressure reading is way too high. You should have no more than 44 PSI. at the most. You might want to put the original back in or return this as defective. Hope this helps and thanks again for using 2CarPros.
Danny-
PACIFICISLANDER
  • 239 POSTS
I'm taking this reading at the pressure regulator return line. I've change the regulator 3-times. what's next?
DANNY L
  • 5,648 POSTS
Hello again.
Have you used compressed air to blow out the fuel lines? Maybe there could be a restriction. If not something must be going on with the regulator or it's an incorrect application maybe possibly defective. Hope this helps and thanks for using 2CarPros.
Danny-
