Fuel pressure car is still hesitant?
2020 HYUNDAI TUCSON
85,000 MILES
ROBERTS.EDWARD93
So I replaced fuel pump assembly fuel pressure sensor and high pressure fuel pump and my car is still hesitant. Is there any other thing I can replace to fix the problem
Dec 14, 2025 at 12:45 AM
STEVE W.
  • 15,239 POSTS
Which engine? 2wd or AWD? What do you mean by hesitant? What does it actually do? Any CEL or other lights on? Flashing? What did the pump pressures do during testing?
Dec 14, 2025 at 6:34 AM
ROBERTS.EDWARD93
It’s a 2.0 awd check engine light is on and I will push the gas and it won’t accelerate very much and I will be driving and car feels like it’s kicking back
Dec 14, 2025 at 8:38 AM
STEVE W.
  • 15,239 POSTS
OK, that sounds like reduced power mode, what codes does it have? There are a lot of items that can trigger reduced power mode, fuel, ignition, transmission all can trigger it, even an issue in the braking system can cause it. From the "kicking back" it sounds like ignition or timing. So please list any codes it has in all the systems.
Dec 14, 2025 at 11:16 PM
ROBERTS.EDWARD93
The codes are p0090 p0091 p262b
Dec 14, 2025 at 11:52 PM
STEVE W.
  • 15,239 POSTS
OK the first two codes are both circuit codes, IE a wiring issue. The first one is an open circuit while the other is a short to ground, both on the same circuit. Those are the wires from the valve on the rear of the engine to the ECU. The other code has to do with the first O2 sensor. I would check that area of the harness over, it could be that the wiring got close to the exhaust and melted to it or was otherwise damaged. Especially as those codes could all be a result of harness damage.
Dec 15, 2025 at 6:10 AM
ROBERTS.EDWARD93
My car keeps hesitating to accelerate. It keeps kicking back while I’m driving. Check engine light stays on. Diagnostic machine gave me code p0090. I replaced fuel pump assembly. I replaced high pressure fuel pump. I replaced fuel pressure sensor. I replaced upstream o2 sensor. It runs better but still kicks back and hesitates to accelerate. Any advice of what else it could be?
Jan 12, 2026 at 3:09 AM (Merged)
AL514
  • 5,610 POSTS
Hello, for that code (P0090) I am getting "Fuel Pressure Regulator 1 Control Circuit/Open", so a circuit code is different than a performance code. The wiring diagrams show the fuel pressure regulator being 2 wires that go back to the ECM. So although you replaced the high pressure pump, this is going to be a issue with either the wiring/connector pin issue with the control valve, or an ECM fault. Ill post the wiring diagrams for you. This is just a two wire valve, looks like a White wire and a Pink wire at the High pressure pump. The Fuel Rail Pressure sensor will have 3 wires. If you have not changed the oil yet after the new pump installation, I would do that as well before driving anymore. When the high pressure fuel system has an issue and things go out of balance, a GDI system will always end up with fuel in the oil, which causes an overly rich condition as well. See if the oil is over filled or smells like gas,
Let me get the wiring diagrams for you so you can check the wiring to the ECM, I know the ECMs on these vehicles is usually right in the engine compartment next to the air filter housing.
AL514
  • 5,610 POSTS
Heres the service info for this code, diagrams 2-3 show the GDS (which is the Hyundai factory scan tool), but the live engine data is the important part, you can still check these same data PIDs on an aftermarket scantool. Diagram 5 is the aftermarket wiring diagram and the rest are the Hyundai oem PCM wiring diagrams. Diagram 9 is the PCM pinout so you can check the wiring from the Fuel pressure control valve to the PCM. Notice on the oem wiring diagram that the control valve has it's 2 wires twisted, so the White and Pink wire at the High pressure pump harness you may find twisted together. This is the best way to ID the correct wires for the control valve.
It looks like there are no connectors in between the control valve and PCM, so that makes things a little easier.
Let us know what you find, or if you need further help.
