Low fuel pressure
160,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
LESSISMOR
Have replaced fuel pump two times last three months and now fuel pressure is only 23 lbs. should be 56. Car will run but not at freeway speed.
Aug 19, 2019 at 12:40 AM
Good morning,
Are you using new or used pumps?
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
What brand pumps?
Did you make sure the tank is not contaminated causing the pumps to fail?
Did you verify correct voltage to the pumps?
Aug 19, 2019 at 12:46 AM
