Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Equinox
Fuel System
Fuel Pump
Not Working
Low fuel pressure
2006 CHEVROLET EQUINOX
160,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
LESSISMOR
MEMBER
1 POST
Have replaced fuel pump two times last three months and now fuel pressure is only 23 lbs. should be 56. Car will run but not at freeway speed.
Aug 19, 2019 at 12:40 AM
Experienced Mechanic
Good morning,
Are you using new or used pumps?
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
What brand pumps?
Did you make sure the tank is not contaminated causing the pumps to fail?
Did you verify correct voltage to the pumps?
Aug 19, 2019 at 12:46 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
