Fuel pressure
150,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
CULLY RUTHERFORD
What should the fuel pressure be on this?
Jul 1, 2018 at 7:15 AM
  • 110,248 POSTS
The pressure specifications are as follow:
At idle/without vacuum to regulator: 43 psi
At idle/with vacuum to regulator : 34 psi
Here is a link which shows how to check pressure and the regulator. The regulator on your vehicle is controlled by engine vacuum, so this link may be beneficial.
Jul 1, 2018 at 12:50 PM
