Truck was missing horribly and was wet out thought might be misfiring caused by moisture. tuned up, wires, plugs, cap, button. started still missed. replaced fuel pump and fuel regulator. will start good throttle response but slowly starts to miss and will not accelerate. turn off restart and accelerates fine but shortly starts to miss and will not accelerate. checked pressure at rail 50 lbs when you try to accelerate pressure would fall all the way down to 5 lbs. is new pump bad or should I be looking somewhere else?
Feb 16, 2020 at 2:07 PM
