fuel power supply
120,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
SPRS1122
Draws too much current, melting pin #4 on fp relay
Sep 5, 2016 at 5:55 AM
WRENCHTECH
  • 20,760 POSTS
That's not because of too much current. It's usually because of a weak contact at the wire terminal causing high resistance which creates the heat.
Sep 5, 2016 at 8:24 AM
SPRS1122
Thanx. Got a new plug for the relay. Fixed. Thanks
Sep 5, 2016 at 8:28 AM
WRENCHTECH
  • 20,760 POSTS
You probably want to change the relay also.
Sep 5, 2016 at 8:31 AM
