Fuel or transmission
153,000 MILES • V6 • FWD • AUTOMATIC
BRONCOZ1998
The car won't start up. It sat outside for two months after being in a rear end accident. The front end of the car was damaged and nothing much was damaged to the transmission or the fuel line. Only damaged that was done was to the radiator, bumper, and front head lights. We checked the battery and the battery was bad but we got a replacement and everything electrical works. So with that all being said, that limits down to just the fuel and something being wrong. Is there anyway that some liquid could've frozen up in the gas pipeline and gas isn't getting pushed through to the engine block.? Does this sound correct.? Any suggestions.? Please respond back soon. Thank you.
Dec 23, 2015 at 3:34 AM
SATURNTECH9
  • 30,868 POSTS
So do you have a crank no start or a no crank no start?Also have you checked for codes in the computer?
Dec 23, 2015 at 4:30 AM
BRONCOZ1998
Sorry what do you mean by crank and the computer codes.?
Dec 23, 2015 at 5:15 AM
CJ MEDEVAC
  • 11,000 POSTS
HE MEANS WILL THE ENGINE ROTATE AND NOT FIRE UP
OR DOES IT JUST SIT THERE DOING ABSOLUTELY NOTHING!
Dec 23, 2015 at 9:06 AM
CJ MEDEVAC
  • 11,000 POSTS
OPPS MISSED THAT
CHECK ENGINE LIGHT BEING ON MEANS THE COMPUTER DETECTED A PROBLEM. THERE IS A PLUG IN ON YOUR VEHICLE THAT A POPULAR PARTS STORE CAN HOOK INTO AND RETRIEVE "CODE #s". WRITE DOWN THE ACTUAL NUMBERS (EXAMPLE "P0123") THERE MAY BE SEVERAL. (YOU COULD DO THIS TOO, IF YOU HAD A $60 OR SO SCAN TOOL)
SATURNTECH9 WANTS THE CODE #s, NOT WHAT THE GUY AT AUTO WORLD SAYS THEY MEAN (CODE INTERPRETATIONS DIFFER- HARD TO INTERPRET ANOTHER GUYS INTERPRETATION (NOT KNOWING THE ACTUAL CODE)
THE MEDIC
Dec 23, 2015 at 9:14 AM
