Intermittent no start and running rough
103,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
SCOTT BECK
Runs rough and sometimes will not start. Fuel or air issue?
Dec 1, 2018 at 12:34 PM
  • 110,248 POSTS
Hi Scott and thanks for using 2CarPros.
It could be a fuel or air issue. Is the check engine light staying on when it runs? When was the last tune up? Have you checked fuel pressure? Have you checked for vacuum leaks?
The idea that it will not start at times makes me think fuel. However, that is a guess at this point. Take a look through this link and see anything helps. It discusses common reasons for a no start condition. Of course, this would be most beneficial when it refuses to start, but I want you to see the common problems.
Here is a link that describes in general how to check fuel pressure:
Here is a link that shows how to check for vacuum leaks, which can also cause it to run rough:
If the check engine light stays on, you need to have the computer scanned for diagnostic trouble codes. Here is a quick video of how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people do not own a scanner. However, often times parts stores will do it for free.
Please feel free to ask questions or let me know if you need additional information. If you find there are trouble codes, let me know what they are.
Dec 1, 2018 at 1:34 PM
