1998 Dodge Stratus runs rough when in drive
RWROOSTER
  • 1998 DODGE STRATUS
Engine Performance problem
1998 Dodge Stratus 4 cyl Front Wheel Drive
Runs fine at ideal but when you put it gear to drive runs rough.
Tuesday, August 10th, 2010 AT 2:23 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Tuesday, August 10th, 2010 AT 3:24 PM
MULDOON
  • 79 POSTS
Check the top motor mounts, I replaced mine on 96 stratus what a difference, if you need any input let me know, Declan.
Friday, September 3rd, 2010 AT 5:28 PM
