scan for codes and check fuel pressure with a gauge auto parts rent it. try another key as well if you have one
Jan 25, 2016 at 7:18 AM
OLDADONIS
MEMBER
will run fine for 45 seconds or so
Jan 26, 2016 at 2:58 AM
HMAC300
✓Experienced Mechanic
did you try another key? the one you have may be bad so security system is shutting car down. do not get another key made if you do not have an extra as it will need to be programmed into your vehicle to make it start.
