Fuel neck/tank lines replacement?
240,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
BAYWAL
Over the holiday weekend someone causing trouble crawled up under my car and cut a gas line I assume intending to siphon my tank. However, when I went to fill my tank gas was not flowing into the tank but instead onto the ground. I got a fuel filler neck, but it wasn't the part I needed. What is the part I am in need of?
Jul 10, 2024 at 6:14 AM
CANNON1349
  • 861 POSTS
Could you possibly send us a video of what is happening? Did you drive to the gas station or are you filling it with a gas can? It may be the hose on the filler neck disconnected, this is intended to keep gas from running up and out of it during filling. Otherwise, there is a thick rubber hose going from the filler neck to the gas tank, both of these are big possibilities.
Hope this helps,
William
Jul 10, 2024 at 9:34 AM
