Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Fuel System
Tank
Filler Tube
Replace/Remove
Fuel Neck Hose replacement?
2002 DODGE RAM
200,000 MILES • V6 • 2WD • AUTOMATIC
LOPES818
MEMBER
1 POST
The hose that connects from the fuel neck filler to my gas tank needs to be replaced but I am having trouble getting the new hose on.
Nov 23, 2022 at 6:33 AM
Experienced Mechanic
Does the hose seem too short or something to that extent? have you been able to make a connection on either side of the rubber filler tube?
Also, make sure when you attach the hose to the filler neck that you align it correctly. See pic below.
Let me know if this helps.
Take care and Happy Thanksgiving.
See pic below.
Image (Click to enlarge)
Nov 23, 2022 at 3:09 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
