No pressure from the fuel pump to the rail
166,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
FLYCAT
I'm having a hard time figuring out why there in no pressure from pump to rail. everything is on rightvansc. there is fas in the tank almost full actually, yet still no fuel at rail.
Jun 14, 2022 at 1:33 PM
  • 110,251 POSTS
Are you sure the fuel pump hasn't failed? When you first turn the key on, do you hear the pump prime for approximately 2 seconds?
Also, there is an inline fuel filter between the tank and engine. It is mounted on the passenger's side frame rail. See pic 1 below. Has that been checked or replaced?
See pic below.
Jun 14, 2022 at 3:10 PM
