fuel line fitting
174,750 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
VAUGHN WHISNANT
im trying to order the fuel line fitting that hooks to the barb comming off the tank it needs to be a 90degree fitting
Oct 14, 2020 at 4:49 AM
Can you get a picture of the fitting that you need to connect too? There aren't specific replacement parts for these with a part number so we just need to see what type it needs to be and then we can find the one that will fit. They are more of a general part that more or less you just find one that will work.
Let us know if you can get a picture and then we can locate what is needed or even come up with an idea that can be a good substitute. Thanks
Oct 15, 2020 at 3:54 AM
