Fuel light turned on
285,000 MILES • TURBO • 4WD • AUTOMATIC
CHRISTIE.M
My fuel light came on one day while I was driving. so I went to put fuel in the next day and I filled up my tank but the fuel light remained on. The fuel light still remains on even though I filled the tank to the very top. Why is the fuel light remaining on all the time?
Apr 25, 2019 at 8:04 PM
SCGRANTURISMO
  • 4,897 POSTS
What does your fuel gauge read when you fill it up?
Thanks,
Alex
2CarPros
Apr 25, 2019 at 8:09 PM
CHRISTIE.M
The fuel gauge needle just stays down the bottom near empty and the low fuel light stays on even though I fill my tank right to the top.
Apr 25, 2019 at 8:10 PM
SCGRANTURISMO
  • 4,897 POSTS
Okay, this sounds like it could be a problem with your fuel level sending unit. It is usually connected to the fuel pump hanger located in your fuel tank. I do not have a listing for your vehicle in either of my reference materials, so we will have to do this without any diagrams. I have a link below for you to go to. It is a guide on replacing a fuel pump, but that's okay because the sending unit is usually on the fuel pump hanger, so the fuel pump assembly will need to come out of the fuel tank anyways. Please go through it and get back to us if you have any other questions.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Thanks,
Alex
2CarPros
Apr 26, 2019 at 2:45 PM
CHRISTIE.M
So I’d have to replace the fuel pump?
Apr 26, 2019 at 5:22 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
No. The sending unit is usually part of the fuel pump hanger, which the fuel pump goes into. The hanger is what would need yo be replaced. The fuel pump will come right out of the hanger and should have a hose and an electrical connector to remove.
Thanks,
Alex
2CarPros
Apr 26, 2019 at 10:44 PM
CHRISTIE.M
Okay, thank you for your help.
Apr 26, 2019 at 11:45 PM
  • 55,710 POSTS
Apr 29, 2019 at 6:04 AM
