Fuel leak?
200,000 MILES
TONY LOKI LACROIX
The fuel line has a hole in it up where you put the gas in it. He wants to do a 2 in to 2in connector to fix this. Would it work or any other suggestions. Its right on the back side of where you out the fuel in at the pump
Jun 18, 2023 at 2:18 AM
  • 110,248 POSTS
Is there a reason the fuel filler tube isn't being replaced? That is what should be done. As far as using something to connect pipes, I don't feel it would be safe.
As far as if it will work, I would have to see what is being suggested. Can you provide a pic or something for me to see?
joe
Jun 18, 2023 at 3:31 PM
