fuel issues
245,710 MILES • 4 CYL • MANUAL
KWASI TWUM
Sometimes as you are on the road the car quickly stops as if there is no fuel in it. It also takes longer time before you can start it.
Apr 17, 2018 at 4:07 PM
  • 31,937 POSTS
Best to run a fuel pressure test and check that the fuel filter is not blocked. if it has not been replaced for some time it will be a good idea to get it changed now.
Apr 17, 2018 at 9:25 PM
KWASI TWUM
To locate the fuel filter too has been the problem. We cannot find where it is located.
Apr 17, 2018 at 9:53 PM
  • 31,937 POSTS
i do not have very much information in this model, but doing an online search it looks as if it is an inline filter. so just follow the fuel lines and you should see it, if nothing is seen it may be part of the pump in the fuel tank.
Apr 17, 2018 at 10:11 PM
KWASI TWUM
Thank you Boss.
Apr 17, 2018 at 11:57 PM
