fuel issues
102,000 MILES
I_FLY_DS
i have a 2000 ford explorer v8. i turn the key on and the fuel pump runs with engine off... weird, secondly the engine wont start but will fire when i force feed fuel in to intake.
third i have hooked up obd2 scanner and it wont retreive data??? help"
Apr 17, 2013 at 6:16 AM
JDL
  • 16,098 POSTS
What your hearing may be the initial prime? When you first turn the key on, no crank, the pump will run for a few seconds, then stop if no rpm signal. Use a gage and check fuel pressure, check for injector pulse.
If your code reader won't work, check pin 16 at the datalink connector for voltage.
Apr 17, 2013 at 7:20 AM
I_FLY_DS
Yeah normally the prime lasts about 3 seconds. The pump never stops running though. And i get a reading of 64 psi at the fuel rail
Apr 17, 2013 at 8:19 AM
I_FLY_DS
Pin 16 also shows voltage
Apr 17, 2013 at 8:23 AM
JDL
  • 16,098 POSTS
I can't tell what's going on? Have you tried a different code reader?
Maybe the fuel pump relay is hung-up or a faulty computer. Can you check for injector pulse?
Apr 18, 2013 at 4:04 AM
JDL
  • 16,098 POSTS
Can you check voltage and ground at the fuel injector?
Apr 18, 2013 at 4:05 AM
