Not getting fuel to the cylinders
170,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
KYLE BENJAMIN1
i changed my head gasket because it was leaking and now my fuel injectors wont open. i checked all fuses and relays got good fuel pressure to fuel rail, but no fuel to cylinder.
Sep 4, 2020 at 4:53 AM
Couple things. How are you checking the injectors to tell they are not firing?
Also, what codes do we have? I suspect we would have to have something if the PCM is not firing the injectors. Otherwise we need to make sure there are no connectors loose or not connected. We should have some codes if this the case.
Let us know this info and we can go from there. Thanks
Sep 4, 2020 at 12:28 PM
KYLE BENJAMIN1
i am getting trouble code po129 and a code for the camshaft and crank shaft sensors. I have the fuel rail pulled out of the plenum with the injectors still connected and when I turn the engine over I get no spray out of the injectors. is it possible when I was raising and lowering the engine I pinched a wire? I have also double and triple checked to make sure I have everything plugged in.
Sep 5, 2020 at 12:58 AM
