The vehicle was running fine when I arrived at my destination, I was there for 15 minutes and went to start the vehicle and it acted as if it was out of gas, crank but no start. Checked pressure on the fuel rail and got nothing. So replaced the fuel pump and the inline fuel filter. Same problem cranks but no start. Checked fuses and relays all good, couldn't hear the fuel pump engage when the key was in the start position. Sprayed a shot of starting fluid into throttle body in ran for a few seconds and then off. Fuel pump only gets power when in cranking mode. I thought it might be anti-theft, tried resetting that but to no avail. Don't know where to go from here.
Dec 4, 2022 at 3:45 PM
