just recently had my head resurfaced at a shop , i labeled all lines,vacuum and injector lines as well as electrical connectors,now that ive put everything back together i cant seem to get the injectors to fire. I took out cam shaft for new seal and one the cam itself theres a dowl which lines up with thew belt pully ,do i need to correct this ,can it be out of timing? i have spark at the plugs i checked that ,all fuses are ok .when im cranking the engine it puffs alot niot smoke just the noise i also tried just pulling off fuel rail and seeing if the injectors are firing fuel they arent so im assuming thats my issue? Please help.
May 7, 2013 at 2:45 AM
