Where are the Fuel injectors located?
147,544 MILES • 4.9L • V8 • 2WD • AUTOMATIC
JEVANTE7
Where is the location of the fuel injectors?
Mar 18, 2023 at 12:11 AM
  • 110,248 POSTS
The fuel injectors are between the intake manifold and the fuel rail. See pic 1 below.
As far as replacement, you will need to disconnect the negative battery terminal first. Next, the fuel rail is unbolted. Once you have done this, the injectors are accessible.
I attached the directions for replacing them for you below. (Last 3 pics) Also, here is a link that explains in general how it is done. Actually, you will likely find this more helpful than the manual's directions. LOL
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Let me know if this helps or if you have questions.
Mar 18, 2023 at 5:31 AM
