Fuel Injectors swap?
97,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
TABITHA LACHENEY
I have the car listed above. I need to know if a 2004 Chevy Silverado 4.3 fuel injectors are interchangeable. I have those available already. Wanting to make sure they will work.
May 25, 2023 at 7:24 AM
  • 110,251 POSTS
No, the fuel injectors from a 2004 Chevy 4.3L engine will not directly fit a 1996 Pontiac Firebird 3.4L engine. The fuel injectors are designed specifically for each engine model and have different specifications, including flow rates, electrical connectors, and physical dimensions.
I attached the part numbers for both below.
Let me know if this helps or if I can help in any way.
May 25, 2023 at 2:31 PM
