Fuel Injectors
159,500 MILES
LIZHOGAN
Last year-I was smelling gas so I went to have my truck checked (brought it to AAA) They broke my fuel pump when they were looking for the problem-so I had to replace it-since then the check engine light has come on-so I went back to AAA & they said its the ERG Valve-replace that-the check engine light still stayed on-I spoke to someone & they said we need to replace the fuel injectors.
How many fuel injectors does a 2000 GMC Jimmy have?
Do you think the fuel injectors is whats wrong? I know its an admissions problem but I can't figure out which problem it could be.
Thanks!
May 24, 2013 at 10:47 PM
JDL
  • 16,098 POSTS
What are the applicable code numbers? Some of the national brand autostores will check codes for free. Write down the code numbers and post them here. Me or somebody will talk to you.
Are there any driveability issues? If you have the spider fuel system, it is known for problems.
May 25, 2013 at 2:21 AM
