Fuel injector with no voltage
185,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
JKINARD
  • 47 POSTS
I have a 2003 Dodge Durango 4.7 2WD SLT. I noticed that it has no power on acceleration. I bought it used and got a diagnostic on the CEL. It said I had misfires on several cylinders. I got new coils and new plugs for all eight cylinders. I ran fine for awhile. Then, it began to run sluggish again. I checked the coil harness with a noid test light and everything was good. I checked all the fuel injector voltage harnesses and #7 was out. I replaced it tested it and it was good. Drove it for a little while and began to have the same problem. Went back and checked the injector voltage again and that one AND another one was out (#7 ). I took #7 back off, tested the line and I had voltage again. Reconnected the same replacement harness and I still had voltage (????). Plugged it back up and noticed the same sluggish problem.
Unplugged it immediately and no voltage again. How do I solve this no voltage to the fuel injector problem without constantly attaching new harnesses?
Oct 1, 2019 at 7:04 AM
  • 55,694 POSTS
What happens is the injector shorts out and overheats the injector driver in the PCM. I would replace the injector. here is a guide to help walk you through the repair:
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Please run down this guide and report back. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Oct 3, 2019 at 6:30 AM
