dropped something in the fuel injector port. I have used a magnet but it isn't there so where did it go and how do i find it?
May 3, 2013 at 1:00 AM
KHLOW2008
✓Experienced Mechanic
What was dropped into it?
Are you sure it went into the port?
How big was the item?
Has the engine been started?
May 3, 2013 at 1:44 AM
BLACKFIN88
MEMBER
A cheap screwdriver shaft. The handle pulled off and the shaft fell in. It is about 3" long with diameter of a 10 guage wire. I'm sure it is in there. I haven't done anything to the engine. I am reaching into the port about 8" with a magnet but i think it went farther
May 3, 2013 at 5:05 AM
BLACKFIN88
MEMBER
The screwdriver shaft is straight so do you think it could have made it to the oil pan?
May 3, 2013 at 8:38 AM
KHLOW2008
The fuel injector port does not lead to the oil pan. It goes to the intake manifold and into the cylinders. Remove the spark plug and use a flexible magnet to see if you can retrieve it from there.
