Fuel Injector Line, cylinder one not working?
210,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
FRANKYE972
Cylinder 1 is not working. I tested it with a test light and the signal light only blinks at start up. Once the engine is running the line just shuts off.
May 25, 2023 at 4:16 PM
BORIS K
  • 836 POSTS
It sounds like a possible intentional injector shut down by the engine management system.
This is done when the system detects a misfire on that cylinder and shuts down the injector to prevent over fueling and possible resulting catalytic converter damage.
A good video regarding injector shut down:
https://youtu.be/v9csp3-4VSs
and
https://youtu.be/3plr-FsLwCk
I would suggest to next carry out a CAN-scan using a suitable diagnostic tool
How to:
Have you checked the ignition system, coils and spark plugs?
Cheers, Boris
May 25, 2023 at 6:20 PM
