Where is the Fuel injector fuse located?
161,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
JASON DEZIEL
Fuel injector fuse location on the car listed abovce TSI.
Jan 20, 2023 at 10:38 AM
  • 110,248 POSTS
There are two fuses that power the fuel pump module. See pics 1 and 2. Both are in fuse panel C (bottom left of dash).
If you look at pic 3, I circled the fuses to help locate them. Note that when you check a fuse, first make sure the fuse is good. If it is, then you should always confirm there is power to and from it.
Let me know if this helps.
joe
Jan 20, 2023 at 2:14 PM
