Fuel injector fuse and fuel pump fuse location
150,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
FREDDIE HILL
Car has set 10 years. No fuel going to throttle body. Turned key on no fuel moving, have line off at throttle body. Thanks
Aug 11, 2025 at 10:43 AM
  • 55,540 POSTS
Yep, after 10 years, the fuel tank will need to be removed and flushed out and the fuel pump and fuel filter replaced. Fuel turns to goo after that much time.
Aug 12, 2025 at 1:47 AM
FREDDIE HILL
I was asking where the fuse was for fuel pump and fuel injector fuse?
Aug 13, 2025 at 5:55 AM
  • 55,540 POSTS
My bad, here is the location of the fuel pump relay and the fuse is a little harder to find by if you have power to the #1 terminal of the relay the fuse is okay. Check out the images (below). Let us know how it goes
Aug 14, 2025 at 1:01 AM
FREDDIE HILL
I'm assuming this is under the dash? Thank you
Aug 14, 2025 at 6:36 AM
  • 55,540 POSTS
Yes, I believe so, this car only has one fuse panel correct? If so then the fuse should be there.
Aug 15, 2025 at 4:31 AM
